I have Apexi N1 coilover. like thse:
On the front, they are perfect. On the rear.. From rims to fender, I have 89.30mm and 73.45mm on the other side.
What I did is: Took the lower portion of the thread ( you can see there's 2 portions of thread) and the one who was 89.3mm got lowered to the MAX.
The passenger side at 73.4mm has been highered to the maximum. When you sit under the car, you can clearly see that the driver side has only 5mm of thread and the passenger has propably 25mm of thread. Still there's a 17mm difference when the car sit on the ground.
So what can it be !?!? I have to play with spring ? unloose the spring (i.e: decompress the spring?)
I could deal with the fact that the driver might be slighly higher considering the fact that I weight 200lbs and once sit in the car, it might lower the car by 5mm ( for exemple purpose!) but 17mm is way too huge of a difference. the car drive like sh*t and I want it aligned but I can't till I fix this problem.
Please help!
Please help!
