just got my innovate wired up and in and had some questions about my A/F ratio
im running a precision 5252e turbo on a s2 rb25det stock manifold external wastegate screamer pipe fmic walbro 255lph pump full 3" exhaust straight off the turbo
Wide open throttle i have a 10.7 a/f ratio @ 7psi
idle is anywhere from 13.8-15.2
after a pull if i pop the clutch in the idle drops to 150-300 rpm and i richen up to 9.8 a/f ratio but after a couple seconds it will climb back up.
as well as if im in 4th cruising its in mid 11's but if i take my foot off the gas completely and let it ride it jumps up to 21.9 a/f ratio
Are these numbers pretty normal? Just would like some insight on how its running this is my first wideband
