Im guessing using sealant/gasket maker would be pointless since it would probably just burn off?
Installing metal exhaust gasket
You need to be more specific.
Where on the exhaust?
Yes liquid gasket is point less in all applications, you can use reinforced high heat rubber ones on the exhaust after the cat , but for sure not for the manifold.
Sent from my HTC Magic using TapatalkLast edited by RABBIT; 09-20-2012, 01:38 PM.
Originally posted by Voodoo_ChildR32 View PostI've used hi temp copper silicone with zero issues on more than one application. Manifolds, turbos, etc. it is sensor safe.
what compound?
Oh its for my manifold, I have the copper RTV but Im wondering if it will hold up to the heat.Regards,
Ken.
Does it have a max temp on the container?Originally posted by TheyKilledKenny View PostOh its for my manifold, I have the copper RTV but Im wondering if it will hold up to the heat.
You can get the exhaust gasket sealant from places like performance improvements, designed for use on turbo applications. Great for when you start tuning as exhaust leaks will mess with your afr readings. Wish i bought some when buddy at the store recomended it.Dang! You got shocks, pegs... Lucky! You ever take it off any sweet jumps?
Permatex ultra copper high temp rtv gasket maker. Comes in a squeeze tube. Hasn't failed me yet.Originally posted by RABBIT View Postwhat compound?
-Bruce Lee
