hey everyone, so i have a greddy oil cooler/filer relocation that i bought used without any brackets or anything. im wondering where the best place to mount it is, and what brackets i should make. im thinking the best place would be under the battery behind the bumper, mounted on its side so i can drain oil out when doing oil change could also set up some ducting too. what you your guys mounting solutions look like ?
Mounting Greddy Oil Cooler Help
probably going to mount mine there, and then put filter relocation where battery is. ive drawn up a drip tray/holding bracket for the filter block. once i finally make it with some sheet metal and rivets ill post some pics up for sure- Adam
I am mounting mine behind my grill. Made up a heat shield with gold reflective tape on it to separate the cooler from my FMIC. Just need to make up some solid mounting brackets and I am set. I also have most of my inner fenders already removed to fit wide tires and I did not want to have a cooler sitting there.Raw Brokerage, Your RB specialists
R.I.D motorsports
"KRANKY" R32 #theroadto9's
