Just got my rb20 s14 running well kinda.. here we go any input would n be great.
Starts up and dies, will start and idleevery so often but has a very very rough idle, won't rev past 2k rpms sounds likeit hits a rev limiter then dies
Had it running for 15 minutes with brand new plugs and it's running so rich that 4 out of 6 plugs are already extremely black and fills my garage up with so much rich fuel smoke you can't breathe massive exhaust back fire
Plugs in cylinder 1&2 are clean and not firing has spark and fue....l compression test on cylinders 1&2 50psi, 70psi cylinders 3-6 150psi.. don't know why i have such low compression in 2 cylinders
Mods- z32 maf, front facing manifold, fmic, gt2871r, 12 psi,3 inch exhaust, wiring specialties harness,255 fuel pump, stock fuel injectors with a ebay tune chip camewith the swap
Cel code for temp sensor...... any ideasforthe low compression, rough idle and running so rich..Bad engine?
