so i've been thinking about this issue since last year
first have a look at my last dyno chart;
so my problem is i'm loosing too much boost throughout the rev range
i'm still making good max power, but only at ~16psi
i'd rather have 17,5psi @ max power, but because of my declining curve, i'd have to set my boost 1,7psi higher and alsmot hit 20psi @ peak
in a perfect world, i want to set it at 17,5 and simply flatline there till the rev limiter
now is the part where i'd like to speculate on whats causing the issue
heres a quick list of my power-related mods;
HKS fuel pump
Sard 720cc injectors
Nismo FPR
Splitfire coilpacks
NGK copper racing plug
R34 GTR N1 turbos
R34 GTR dump pipes
Nismo downpipe
decat
3" Veilside exhaust
ported stock manifolds
divided twin turbo pipe
Apexi power intake
Greddy intercooler
HKS/Greddy I/C hardpiping
HKS SSQV BOVs
HKS 264deg 9.5mm cams
Custom adj cam gears
HKS EVC-S electronic boost controller
i've had this problem for years now
2011;
2010;
i know this problem is not from the fuel nor the ignition system
its not from the catback, since i changed it last year and gained 30whp but with the same boost curve
could it be the BOVs leaking? in my opinion the way the SSQV work its kind of impossible to leak
don't think its the dumpipes, since the ones i got are not the big like the Tomei, but still much bigger than OE, the downpipe though might not be big enough
so i checked my turbos in 2011, to find R34 GTR N1 in perfect condition
i though it was du to the wastegate actuators, so at that moment i swapped them for brand new Garret units, and adjusted them the same length as OE
now i really think thats where the issue is, i bet the WG actuator springs aren't stiff enough
basically, when you get into boost, trigger the controller, the selenoid sends the pressure to the actuators, lets say 17psi, the actuator spring is rated at 12psi, so of course the actuator opens, but wayy too much, so too much exhaust by-passes the turbine and boost drops, but the actuator is not stiff enough to close the WG a little to keep the boost stable, so it just slowly decreases towards the value on the actuator spring
so now i've started working on the car again, to get it in shape for the 2013 season,
i'm thinking of removing all of the piping over the turbos to access the actuators without taking the turbos out -again-
i'm thinking if i shorten the actuator rod by 2 turns, so about 1/8", it will add preload to the spring at its neutral "closed" position, so instead of 12psi required to open it, it might be 15-16psi, basically meaning the spring will have a big more force to close the WG when/if the boost drops because its too open
basically, what i would want is to set my boost controller at 17,5psi, get my boost to flatline there
i'd loose a bit of torque in the mid range, but would gain soooo much more in the high end
then to balance things out, i'd play with cam timing to get a bit more overlap for quicker spool and better mid range torque, and loose a bit of top end
basically i'd add ~30-40whp from 4500rpm till redline..
as anyone attempted to adjust the actuators on the spot?
can the rod simply rotate inside the actuator or i need to unclip the rod's end to spin it 2 turns? because i would hate to do that in that cramped space..
toughts? ideas? comments? tell me why i'm gay and stupid?
HKS fuel pump
Nismo FPR
Splitfire coilpacks
R34 GTR N1 turbos
R34 GTR dump pipes
Nismo downpipe
decat
3" Veilside exhaust
Apexi power intake
Greddy intercooler
HKS SSQV BOVs
2011;
2010;
