I Just recently purchased my first skyline. It is a gts-4 w/ rb26 swap. Im going to pick it
up in a few days and need help with the towing procedure. I know that you cannot
tow an AWD vehicle unless you use a flat bed.. But in my case im planning on renting a dolly,
pick it up and strap on to dolly, then tow back home. Ive looked around and found that
many people disconnect the drive shaft from transmission to rear diff, thus making it
FWD in a sense. They then put front tires on dolly (off ground) and then leave the back
wheels on the ground.... My question is, do any of you know if this will work and not damage
internal components? and does anyone have a procedure i can follow to take off the
drive shaft? again new to the skyline scene and NEED help ASAP, Thanks in advance.
