Hey guys, as the title says, I'm having some issues with misfiring.
I have just replaced the coils in my 1990 gtr with some Yukon coils (AC Delco d585). This replaced the coils, wiring, and ignitor. The reason I replaced the coils in the first place was due to a miss. I tested the factory coils and they were arcing from the sides. After the new coils It still had a miss, so I replaced the old copper plugs with some platinums. It then ran fine for about 3 weeks, then started missing again.
I then replaced the plugs again with some iridium plugs. 2 weeks later and its missing again! The Iridium plugs i used were NGK BKR6EIX-11
All of the plugs that I have taken out have looked fine. No fouling, no cracks, no visible signs showing anything wrong. I also ohm testing the "bad" plugs and they are within spec.
Every time I replace the plugs the miss goes away for a bit only to return. I am running out of ideas here and don't have an unlimited money supply to keep throwing parts at the car hoping for a fix.
Other things recently tested/ruled out:
CAS
MAFS
Fuel Pump
Fuel Injectors (all firing but not really ruled out yet)
Boost/vacuum leaks
Fuel filter (new less than 5k kms ago)
Compression
I have yet to check the ignition timing and will be doing so this weekend. Could this cause the problem I am having?
TPS has a dead spot on it and needs to be replaced, but I don't see how this would be temporarily fixed with new plugs. I have one on order but it is at least 2 weeks away. (Just so everyone knows a 1996 maxima tps is NOT the same! haha It fits but the .5-5v signal is flipped so you have 5v closed and .48 wide open.)
Any ideas would be much appreciated! Even if they are a long shot, I NEED to get this fixed as my GTR love is going for a **** at the moment!
Thanks!
CAS
MAFS
Fuel Pump
Boost/vacuum leaks
Compression
Thanks!
