So I picked up an R32 GTR the other day. The 4wd and abs lights are on all the time, havent seen them go out yet. Key in ignition, switch to the on position, I can hear the fuel pump priming but NOT the 4wd pump. After i start the car, and drive for about 10 minutes the HICAS light comes on. Not really concerned about the hicas just the abs/4wd. Ive done a bit of reading, and heres what ive done so far:
-Checked all the fuses in drivers footwell, all of them including 4WD are good!
-Checked Fuses under hood, all seem to be good
-Taken battery terminals off, pressed brake pedal for 10 seconds, reconnected. (resetting ecu ?) did nothing
-Had battery tested, Rated for 560 CCA, measured out at over 600. Battery is good.
-Cleaned both posts on battery with a terminal cleaner, nice clean tight terminals.
-My ATTESSA computer does not have a flashing LED, Not throwing any codes ?
-(Power steering/HICAS) resirvior in the trunk is right on max, so the level is good.
-I jumped the two big wires coming from the little relay for the 4WD pump, and when i bridge them I can hear the 4WD pump priming, pump must be good.
-When I manually close the relay, i can also hear the 4WD pump prime itself, so i guess the relay is good too ? Or could it be toast...not sure
-I cleaned grounds on back of spark plug cover thing (silver box)
Im not really sure what else to look for, Im very new to this car, but have done some of the easier stuff that I know how too. If someone on here has some more ideas on what to check (G-sensors ? ABS/Wheel speed sensors ?) And how to check them (voltages ?) Any info would be really appreciated, REALLY wanna feel the car with the AWD working, thankyou to everyone who helps me out ! Remember im new, dont call me an idiot please
