Rattling noise from engine
When you rebuilt engine did you do the whole timing belt service, idler, spring? What about the clutch on the fan? Easy to remove and run engine a short time to rule it out. Hard to tell location of rattling by video. Hope someone on here has heard this specific sound and can help you out further.sigpic
Could be water pump (makes a knocking sound when on the way out), CAS bearings x2 (both can be checked via putting a mechanics stethoscope on each part and listening for the sound). If the fan clutch is stuffed it should lock, spin fan faster than normal. But if didn't replace the mounting washers, it might cause a water pump knocking problem.Last edited by Skym; 09-07-2013, 11:20 PM.RESPONSE MONSTER
