Here's what I have so far:
Front tension rod, FUCA, RUCA, hicas delete with tie-rod oem delete ( replaced with tension arm), I believe I have subframe collar , front and rear strut-bar and Apexi N1 coilover.
Since, I'm pretty much done with my power mod ( Unless I put another +5k for stroker or efr turbos..) I went ahead and bought:
Solid rear diff bushing, solid shifter bushing, center roll adjuster, steering solid bushing, eccentric lockout kit, engine damper ( because changing the engine support is a little too pricey in labour) and was debating if I should go solid rear subframe bushing to replace the collar and Nismo tranny support mount.
Is there something else I'm forgetting ?
