Just trying to make the most out of my actual bolt-on components, you often read that around 600whp its time to move on to 3.5 or 4inch.
So technicly, if you have a 70mm dump pipes matched with a 70mm downpipe, you would need a single 4 inch (100mm) to match the flow of the 2x70mm. With that said:
1) Did anyone had the chance to see back-to-back result coming from 3 inch to 3.5 or 4 inch on a ''mild-built aka 550-650whp'' turbo car ?
2) After reading this article, http://www.tercelreference.com/terce...st_theory.html ( who knows if this is the truth..?), it appears it would be better if the size would come up gradually. However, most Cut-off valve are beeing installed right after the downpipe. Whats your thought on this ? Would you still install the cut-off there and scrap the theory ?
Ideally, I would pay a exhaust shop to install a 4 inch cut-out valve right after the merging of the 2x70mm and reduce it to my 3 inch resonator and keep a very civil 3 inch exhaust.
