anyone have the part number for the R32 gtr rear wheel extended studs? I got the fronts already but searched and cant find the part number that people are using for the rear wheel studs.
Q: Arp part number for 32 gtr rear wheel extended studs?
Don't know ARP parts numbers. I'm looking into buying a set of Nismo and they have two different part number. Front/rear supposed to be different in the nural spline with front at 14.3mm vs 13mm rears.
Nismo 40222-RS045 - 60mm extended front
Nismo 40222-RS025 - 60mm extended rear
if you are not using slip-on spacers i don't think strenghened studs are needed, mine are 23 years and i've tracked the car alot and haven't had a failure yet
and then again, you don't need extended studs unless you use slip-on spacers, as long as you have a thread engagement of 1/2" between the nut and stud its fine
I am running the arp studs fronts are is300 part numbers rear is a gm part number this does convert to a 12x1.5 lugnut however. I still have the package for the rear I will post up part number tonight.91 gtr , 93 rx7 type r and a multicolor 240 スカイライン
