Was reading this article on Speedhunters showcasing a new product from Do-Luck. Simply replaces your stock G-sensor but reprograms your ATESSA and ABS system. Pretty interesting, and a very simple modification. I don't drive my car nearly hard enough to notice any differences, but perhaps some of you who track the car a lot can benefit.
http://www.speedhunters.com/2012/06/...ets-tarzan-ed/
http://www.do-luck.com/tuningparts/t...box/index.html
![](http://cdn.speedhunters.com/wp-content/uploads/2012/06/AY0F2398.jpg)
定価 各¥60,900(税別¥58,000)
Tarzan Yamada applies his knowledge and experience to produce a new G-Sensor that improves 4WD performance under any condition!
The “G Box” is connected to replace the stock G-sensor and responds multiple times faster to control the 4WD system (ACD/AYC/ET-S etc.) Parameters such as Front/Rear & Left/Right torque distribution; duration and timing have all been refined by Tarzan himself over multiple test sessions in many different cars of varying specification.
Optimisation of the G-Sensor signal allows improved acceleration and cornering at levels which previously felt impossible to achieve. The improved traction gained from the G-Box is reminiscent of the feeling from a mechanical LSD but without the associated noise and discomfort.
Whilst differences can be felt under all circumstances, it is particularly noticeable under braking. Improved response time allows full optimised use of the 4WD system to improve stability whilst braking. G-Sensor signals are also sent to the ABS system where the reduced response time improves the performance “feel” of the braking system.Unleash the full potential of your braking system with the Tarzan G Box!
Tarzan G Box has been setup to allow pro level drivers to improve performance on the race track with many top level tuning shops already improving their lap times on the circuit. However, the setup has also been tested by drivers of different abilities on both the road and race track. The results were simple… All drivers improved with the Tarzan G Box on the circuit and also felt more comfortable and safer in their car on the road. Safer and Faster! Tarzan G Box can deliver it all!
