thread pitch of the crank pulley
  • thread pitch of the crank pulley
    i want to know the thread pitch of the 2 small holes in the pulley where u screw in the puller to remove it . thanks!
    On my gtr it was m6x1.0
    hope you didn't break a bolt inside
      For some odd reason im always using m8x1.25 in there.
      But then again it could just be the puller kit I have labeled wrong. Either way a cheap 20 dollar Canadian tire kit comes with the required bolts.
        nah i got a puller with 8 different screw sets and the smallest was too big so im just going to run to grab two bolts ill grab both of thoes just in case.
        thanks ladies!
          You can use the bolts on your turbo elbow on the compressor side if your in a pinch. Thats what I did
            A+ for Zacho the newb came through .
            worked like a charm saved me 75 cents and a trip to home depot
            thanks man!
