for some reason i cant stop watching and laughing at it How does this happen ?
this is not funny !
Not tightening the nuts????
One of the comments mentioned that the owner said on TV that there was not enough thread, half an inch (usually only happens with spacers and I think Nismo sell longer, stronger studs for Skylines to prevent this problem from happening). Also I gather the nuts came off one by one when each wheel became unbalanced.Last edited by Skym; 04-02-2011, 11:57 PM.RESPONSE MONSTER
Originally posted by Skym View PostNot tightening the nuts????
One of the comments mentioned that the owner said on TV that there was not enough thread, half an inch (usually only happens with spacers and I think Nismo sell longer, stronger studs for Skylines to prevent this problem from happening). Also I gather the nuts came off one by one when each wheel became unbalanced.1992 BNR32 SKYLINE GTR
Originally posted by frankiman View Postactually someone mentionned on another forum that he used different nuts for the track wheels, and those nuts had a different thread (M12x1,25 vs M12x1,5) and because of that e could only tighten the nuts about 1 rotation or something1992 BNR32 SKYLINE GTR
Originally posted by frankiman View Postmuch more than that lol1992 BNR32 SKYLINE GTR
Originally posted by frankiman View Postactually someone mentioned on another forum that he used different nuts for the track wheels, and those nuts had a different thread (M12x1,25 vs M12x1,5) and because of that he could only tighten the nuts about 1 rotation or something
Originally posted by Marus92 View PostHalf the thread pitch so half the shear, half the load. BUT you're right, if he torqued to the same spec he probably put too much load on whatever thread he was engaging so it's way more. Let's say ball park 1/4 if the thread is still elastic (or 0 SF if the thread is plastic, which is probably in this case).Last edited by Skym; 04-03-2011, 01:46 AM.RESPONSE MONSTER
Originally posted by Skym View PostThat makes more sense.
So your saying the thread on nut should have been taller (also thicker??), so it touches the base (thicker part) of thread on stud, which is what you mean by elastic. But in this case it was plastic because thread on nut was at the top of thread (thinner part) on bolt and with the same amount of torque that was meant for the base of thread + weight, stresses of drifting car, etc caused the failure of thread?
As for my second comment, if he would of torqued the bolt to spec, he would of applied energy to a weak structure. While the bolt is flat on the rim, torquing the bolt would cause the threads to stretch along the pitch so that it can still turn on it's axe, increasing the pressure applied axially. Since you run twice the pitch in the nut, you have to exert twice the shear and bending on the affected thread to run the same torque. This would probably cause them to go easily beyong their ultimate strength and start deforming plastically (which is, from an energetic point of view, a point of no return) and they'd flat out fail on load or fail by fatigue.
Think it like this. Say you have to run 100lbs of pressure on the bolt with an ultimate yield safety factor of 1.25 (80% ultimate strength). With the right pitch you can, no problem. If you run a nut with twice the pitch of the bolt, effectively going past the 1.25 SF to 160% ultimate strength, and you try to torque it to that spec, you never be able to have that pressure; you'll only end up with considerably less pressure or you'll break the bolt while torquing.
Edit: Ive just realised I was thinking that he was running twice the pitch but it was only 1.2 times (1.5/1.25). Still applies. I guess I was really tired. Still am, didn't sleep last night lol.Last edited by MarusGTR; 04-03-2011, 12:10 PM.1992 BNR32 SKYLINE GTR
