Okay, here's the problem. My R32 GT-R's engine will randomly sputter out and lose throttle, sometimes after some lead-footing, but usually for no discernible reason. The engine will sputter for a moment and then will become less and less responsive in the upper RPM ranges past 2-3K RPM until I finally get no throttle response after that, if that is I lose response while in those ranges. The engine will then bounce off the 2-3K range as if it were the engine cut point. The turbos will spool, but no boost will be built (0 PSI).
It's a mostly stock Skyline GT-R with the only mods being a 3" down-pipe and a Border-tuned ECU (with unknown properties). The engine troubles have been happening long before the ECU was swapped. Checked MAF, spark plugs and TPS: all were fine.
So quite plainly, WTF is wrong with my car?!
Greatly appreciate any help, thx.
ops:
Goddamn Skylines! Hopefully this was a one off.
