Ok so im trying to remove my cam gear cover so i can paint it but after removing all the bolts it still isn't coming off, do i have to dissassemble the whole engine to take the thing off or what.
Cam gear cover removal
for me, it was a b*tch to remove.Need detailing done to your car? I'm open to travel to detail your car :
LMAO...Yes your suppose to have the screws holding the CAS. Thos determine the angle. There should be 3 on the outsides, and then after the bolts you just pull it straight out. And when you put the cover back on make sure you put the bottom in behind the water pump pulley.Originally posted by -Skyline-GTR- View PostOh that stupid thing is the CAS hahahahaha. my bad..Thanks for the help nate
*edit*
Does that thing just twist off or what? cause i have no screws holding it on and its sitting there hahaLast edited by bellis_GTR; 07-22-2010, 03:22 AM.Heart rate 160, I'm goin 260, RB26 run me past you in a jiffy
I know your supposed to. Im saying mine isn't holding onto anything because i took the screws out. ThanksOriginally posted by bellis_GTR View PostLMAO...Yes your suppose to have the screws holding the CAS. Thos determine the angle. There should be 3 on the outsides, and then after the bolts you just pull it straight out. And when you put the cover back on make sure you put the bottom in behind the water pump pulley.
This was the only part i was having trouble with.Originally posted by bobbo View PostWOW! You guys that don't have much experience I really appreciate your ambition to dig in to these cars but for the love of god down load a manual and do some reading before taking stuff apart. It'll save you a ton of time and grief.
