This is my problem with the internet. That 11.6 number you gave that is a very unquantified number. It is based on what someone else has said. Myself i would have no problem running a bone stock GTR at stock boost at 12 AFR on 94 octane. If I knew the source of the 91Octane I would run it there as well.
Cams don't change your AFR. Fuel delivery is based on some calculation Load determined by Airflow volume and mass or manifold pressure and air temp ( speed density) This calculation is then based on the Volumetric Efficiency of the engine.
You are sort of right about higher octane. What it basically boils down to is cylinder pressure or we can get all engineering about this but lets keep it simple. You want max cylinder pressure before detonation occurs. Timing is necessary because (insert long equation here) it takes so many seconds for the fuel to burn. If the engine is rotating faster you need more time to burn. If you use a slower burning fuel(higher Octane) you need more time. So think if timing as the (amount of time to burn your fuel) fire it off to soon and you are working against the piston trying to get to TDC fire it off too late and you lose power and raise EGT's. Yes I just said that high EGT's can be caused by retarded timng and rich AFR kinda go's against that whole internet thing that high EGT's mean you are hurting you are detonating. Next week we will dispell the myth that over 85% duty cycle on your injectors does not burn them out
All knock is frequency you need a sensor that differentiates between frequency to get closer to the actual kock frequency. ViPEC is actually watching a few degrees before ignition and a few after basically creating a window so we can separate normal engine noise and also determine which cylinder is dettonating and retard that cylinder rather than doing a global retard. It is very smart. There are many strategies of setting that up as well to long for this convo. Individual cylinder knock control is awesome though.
Cam
![Smile](http://forums.gtrcanada.com/core/images/smilies/smile.png)
Cam
