stock head studs reusable?
    You can reuse arp studs but you should measure them prior to initial installation, if being re used the original measurement should have not been affected. if it has then replace them with new units.
      ARPs studs are pretty cheap and it's an upgrade, if the engine is out, rebuild it, fix the known bad actors and get new studs. End of story.
      lol
        My ARP studs were recommended to be torqued to 125 ft-lbs, so I did. No problems.
