can anyone tell me what the most effective antilag method isÉ in your opinion that is. And to be truly effective it should work on all turbos including the ceramic ones otherwise its like a workaround. i was wondering if anyone thought that you could install a battery powered supercharger so to say that is in front of the turbos to provide initial boost. as you all must know a traditional supercharger is powered by the driveshaft and while there are some cars that have one of each, it would be extremely hard to install in an r32 chassis. http://www.superchargertuning.com/Nissan/Skyline/
this site says they have a supercharger that can provide upto 5psi of boost in less than a tenth of a second but since its electric it can only run for a minute at a stretch and therefore it only come on when you actually floor it. since turbos can take alot longer to spool up, would this help give you an even power band even with a big blowerÉ im almost positive that it would work the only question is once the turbos come on full blast, could he supercharger take the pressure without blowing itself to bits. its made of metal and is solid construction. what do you guys think
