You say you don't want to rev to 11k but your running very high duration cams and dual valve springs? That doesn't make sense. With that turbo I would run 270/270 10.8 lift max. I ran these on my car with a GT4088r (similair size to yours) and low end power was frustrating at times. I can imagine 280's would be even worse.
for valve springs I would check out Cosworth. The supertechs are way to stiff and most of the japanese stuff is either barely stiffer than stock or way to stiff. Cosworth is the perfect in-between.
Also, I've never seen anyone publish results directly comparing OS valves to factory sized ones. I have heard there are little gains in the under 1000whp world and it doesn't even make a huge differnce above that.
Dsports R33 ran over 1000whp with stock valves. It ran for years with huge power but eventually destoryed an exhaust valve.
