Can someone type my engine code into FAST?
  • Can someone type my engine code into FAST?
    I was browsing online today and found some info on rb26 block codes to tell if the motor is from an r32, early or late, r33 or r34... and from what iv read... its lookin like my motor definetly is not from a 32...
    block code looks like this:
    RB26
    R
    704416X
    I have not gotten under to see if it says 05u Or 27U or 24U or whatever else it could be.
    Just curious I think my car may have an R34 motor in it?? can someone please run that number and see for me please before I get too excited lol
    Mine looks like this but with that above numbers
    1992 Dark Blue Pearl Skyline GTR - 457 rwhp, 404 tq @ 19 psi , chevron 94.
    1991 Gunmetal GTS4 - SOLD
    Originally posted by dah_hunter
    i wait till the lights yellow.. or i lean far and go.. thats what BOOOOST if for..
    anyone able to provide me with some info? I havent found a whole lot to tell me what car this motor came out of... alot of the info I found is vague thats why im asking here if anyone knows for sure what engine codes are from what model year.
      whats the difference between 05u, 27u, 24u? a gtr i might get claimes theres a r33 gtr motor but wouldnt mind knowing if it is or not
        05u is a standard block and the 24u is an N1 as far as I know... you can tell if the motor is an r32, r33 or r34 by the serial number like I have posted. I think mines an r34 motor from the little info I have found. Hoping someone can try and run my motors serial number In fast to confirm
          Why do you think it is a r34 motor? R34 cas? If you use a small mirror you can see the block code
            My block code is in my first post ^^^^ RB26 R 704416X . everything iv found online shows an R32 RB26 as RB26 04xxxxA , R33 motors iv seen RB26 05xxxxA. then I found a thread on gtr.co.uk : http://www.gtr.co.uk/forum/106328-hu...wbie-rb26.html
            In that thread someone states:
            "There should be RB26 writen on top and there should be number starts 06----- or 07----- or 70-----o and look if there is "R" mark at the end or above the last digit.
            There is also 05U or 24U written on other side of the block under turbos and that tells you N1 block or STD block."
            This is pretty much the only info I could find. Some guys on Skylines AU have told other people asking a similar question to run the engine code in FAST and it should say what car that motor came out of.
            And I dont have an R34 CAS but is it not possible to have an R34 bottom end with an R32 or R33 head? or atleast run the r32 cams in the r34 motor and keep the r32 cas??
              i dont know if you can punch those numbers into fast RB26 R 704416X i think fast would need part numbers
