what kinda plugs does the GTR use is it the same as GTS or are they totally different?
spark plugs
No, he means search, this has been covered about 100 times.Originally posted by skyrider32 View Postyou dont know? or you couldnt say?
oem platinum 6heat range 1.1mm gap gtr......gts 5 heat range....ur at 1 bar prolly use ngk bcpr7e/bkr7e vpower copper colder heat range .8mm gap if urs is a gtr
i had bad luck with standard ngk wit bad idle...vpower better for my bnr32
search as there are more optionsToy: BNR32
DD: R50
Go to Can Tire and buy a sparkplug gapping wheel, bend the electrode with the hook, select the 0.8mm ring and check the gap, repeat, profit!Originally posted by skyrider32 View PostJust got back from napa and they wanted $70 each how hard it it to gap plus? As I have never done it/never needed to
I assume you meant 70$ for 6? That's around the standard price.1992 BNR32 SKYLINE GTR
One helluva sparkplug, that's what!Originally posted by DarkCaporaL View Post70$ for one spark plug what the hell was he trying to sell you.
...seriously though, that's messed up.
He still should gap them correctly. Out of my new dash 8s, one was off and I had to gap it.Originally posted by markc32 View Postdooood ngk plugs are pregapped.......ur at 1 bar get an ngk plug that doesnt have 11 in the end of the part number...
i suggest u get bcpr7e/bkr7e which ever is available........@2-3bucks each with .8mm gap already save money1992 BNR32 SKYLINE GTR
