anyone running without catalyctic converter? the reason im asking is i supect mine might be clogged and instead of putting another one i want to just put a straight pipe instead now will this affect the performance of the vehicle?
Only way to find out is to run it from the open downpipe.
I'm running a "highflow cat", per se, without issues. Cut the sensor off since it was rotten in the original (a real high flow) cat. Matched with my kakimoto it sounds boss; the same isn't necessarily true for exhausts that have a high pitch though.1992 BNR32 SKYLINE GTR
A clogged cat will make the car feel like the handbrake is on when you're driving. Best way to test is to just undo the exhaust and see if it makes a difference.
You don't get higher flow from a test pipe vs a good cat, just more noise, environment destruction and the chance to get a 1000$ fine.
EDIT: And yes a test pipe is just a straight pipe that replaces the cat.Last edited by DarkCaporaL; 09-12-2011, 08:48 AM.R32 GTR FULL SERVICE MANUAL DOWNLOAD:
Yes a test pipe is a straight pipe. All it is is a section of exhaust pipe the same diameter and length of your cat with identical flanges on either side and sometimes has a few bungs welded in for A/F gauge,EGT sensor.. It's a hollow pipe.
You will notice the power and it will me much louder like Caporal mentioned. If it's to loud for you add a resonator downstream of the test Pipe or buy a silencer for your muffler thats all I did. Except I love the sound of my car so much I havnt even taken the silencer insert out of the plastic hahaha it's loud !"LAG is the time the guy beside you thought he won"
There are different techniques that people use to clean cat's but I have never tried it. Do some searching you may be able to Restore it and put it back in you want.
How does it sound ? Haha I love mine"LAG is the time the guy beside you thought he won"
Probably involves ramming a pipe through it a couple times.Originally posted by evilgtr View PostThere are different techniques that people use to clean cat's but I have never tried it.
