Ok winter is coming and i want to invest a lot of money into my car !
My goal is to have a complete single borgwarner turbo setup and all what is required with it at the end of the winter.
So i can instal it into my car for the spring ! ( I want to Do track and street )
I wanna do it mostly by myself, I have a garage ,lots of tools,hydraulic lift
My car is a 1989 bnr32 with 120 xxx km(bought it in 2007,kept in a garage from 2008 to 2010(money problem lol), I putted it back on the road spring 2011(joined the army no more money problem LOL)
-Turbo are getting old (runing 1.0 bar on stuck turbo)
-the car is pretty stock
-nismo twin plate clutch
-hawks brake rotor and pads
-yellowjacket coilpacks
-decat pipe
-boost controller/turbo timer
-31/2 exhaust
-I will run a compression test (this week)
Ok i want to get more power, I seek between 400 and 450 hp or maybe a lil more
My questions are:
-Do any of guys have a setup with a Single borgwarner Around this range of hp?
-Can a healthy Stock RB handle 400-450 hp ( with minor modification)?
-What do i need with the Turbo (injector size,wastegate,manifold,dumppipe,ecu,blablabla, etc)?
-Is there any way to reduce lag?
-Which Borgwarner should i use ?
Any help,experience,discussion will be apreciated !
thx,
-decat pipe
-31/2 exhaust
My questions are:
thx,
fully built motor about 20k into it so far ive made 421awhp on rgs heartbreak dyno @12psi. will be bumping up to 29psi in a month or so with a triple plate clutch. however if i was shooting for anything under 500awhp on a stock motor i would stick with twins. n1 are going to be your best bet. with a stock motor stock head the spool time is going to suck and not worth the money. going single is a all or nothing deal. do it right or dont do it at all imho
