Just wondering if I should rebuild my turbos with steel wheels, or look for other ones, not really sure what would work best for me, I don't really wanna go crazy but would like to up the boost a little, or at Least not have to worry about them breaking.can't afford new ones but could spend a good chunk on a good set of used ones in or around Calgary,any input will b appreciated, I've read many threads on this but not sure what the numbers mean, or even which are bigger,lol
R32 turbos, rebuild or no?
I'm planning to put a set of rebuilt stock turbos with steel wheels on my GTR tomorrow. I've heard they can be a bit laggy but I've never experienced it for myself. It depends on your budget and how much power you're looking to get but for a budget build I think rebuilt steel wheeled turbos are the way to go -- less than half the price of your next cheapest option (N1's).
Yeah, that's what I was thinking, a bit more lag than stock but just because the steel wheel, did u order the kit and do yourself? Which one did u go with?guessing it should be fairly easy to do.Wondering of it might b better to have them done somewhere, but like u said budget is key, mine is low, lol,
As the description states, the assembly is balanced so NO. Once assembled properly there is no requirement to balance again. As long as the manufacturer balanced the assembly, indexed the turbine and the compressor then they should be good. Each compressor and turbine has be paired together aswell.Last edited by bobbo; 02-08-2012, 04:21 PM.
Just had a pair of R32s rebuilt to steel with all new parts minus a comp wheel. Parts came from Germany. Cost 1400 cash.
If you use all new OEM gaskets, crush washers, studs, nuts and mani washers. $500 give no take.
Garrett 2860R-? go for $2200 give or take
Tomei kit go for 3200 give or take. Includes all new gaskets, studs, crush washers, nuts and mani washers.
IMO if your on a budget rebuild em yourself or send em away. But if u have the money, get the Tomei's because it comes with all new everything u need for a clean reliable install.
Also its not an N1 upgrade unless you machine the housings because the wheels are bigger.
