So guys i have a fully build head:
Tomei procams 270 duration 10.25mm lift
Supertech dual valve springs with titanium retainers
supertech valve guides/seals
Greddy Timing belt
Arp Head studs
tomei 87mm 1.2mm head gasket (and full tomei metal gasket kit)
Oem nissan gasket kit
tomei adj cam gears
5 angle valve grind!
Basically ive spent hours on hours tuning my car and so far have achieved 512awhp @18psi on rgs mustang dyno. One problem. I am running a power fc djetro for my engine management and during my last tune my knock count started reading 70-100 regardless of how much boost or timing was pulled. Tuner basically said that knock sensor must be gone or cracked. So last week I swapped out the knock sensors for a working set and knock count is still the same. Reads 100+ at start up and 60-110 after a full boost pull. So after talking to a few tuners again we have come to the conclusion that due to my stiff dual valve springs and my decently sized large cams the knock sensors cant read accurately. Which sucks since there is no aftermarket alternative for measuring knock and kinda makes tuning for high boost (i am bumping up to 29psi) hard since we have to listen manually for detonation. just wondering if anyone has ran into this problem before or have any other possible theories?
Greddy Timing belt
Arp Head studs
tomei adj cam gears
a money pit lover I guess.
