Over the winter I installed HKS Hipermax 3 coilovers on my R33 GTR and lowered it to 355mm(measured from wheel center to fender) and also installed whiteline adjustable control arms on the rear and camber kit on the front. Today I took the car to the shop for an alignment, they didn't have the specs for it so I did a quick search and found what the standard settings should be. After the alignment the car is pulling to the right so I did some more searching and found this http://www.risingsunperformance.co.u.../BCNR33GTR.pdf
All the adjustments are within the min and max specs however I did not have the caster side-side adjustment spec when the alignment was done. So the difference in caster from side to side may be greater than the recommended spec and causing the pull to the right? I also wondered if the standard alignment settings should be used for a lowered car or should the settings be altered?
Any help on this would be appreciated.
