i am in need of wider fenders for my GTST so I can tuck my tires under the fender. i put wider wheels on and they poke out from the stock GTS fenders a bit and i cant go very low in the front as a result. Anyone know if GTR front fenders are wider than GTS front fenders? Or should I find wide body fenders? I need like 20mm to tuck inside the fender. thanks
R32 GTR Fenders on a GTS
gtr fenders are wider by I think 30mm but I dont think the front bumper will fit. but I think vented fenders are wider (like 20mm) and you wont need to change your bumper. I hope this info is correct and helps you in your decision making1991 skyline GTR
1969 corvette
1989 cavalier Z24
1991 skyline GTR
1985 VW scirocco
Ive seen GTST with a GTR bumper before.. also my R32 is a Type M so the front bumper is a little different, maybe it will fit.Originally posted by dark_sky View Postgtr fenders are wider by I think 30mm but I dont think the front bumper will fit. but I think vented fenders are wider (like 20mm) and you wont need to change your bumper. I hope this info is correct and helps you in your decision makingWTB: GTR front fenders and indicators
1987 RX7 Turbo II
1990 Fairlady Z Version S
1991 Skyline GTS-t Type M
makes sense.... so the issue for a GTST bumper fitting on GTR fenders would be that the corners dont go far enough in? or that its wider...??Originally posted by Nismo_line View PostYes but when you put a Gtr bumper in the gts the corner of the bumper sticks into the wheel well about 1/4 of a inchWTB: GTR front fenders and indicators
1987 RX7 Turbo II
Just do a search , all your questions have been answered in over 10 threads.Originally posted by jinglebell17 View Postmakes sense.... so the issue for a GTST bumper fitting on GTR fenders would be that the corners dont go far enough in? or that its wider...??
