plan to fit my NISMO fuel pump the weekend just in time for mapping.
i have this along with some cleaned and flow tested sard 700s and NISMO afms to match my 2860-7s for some resonable boost (1.2-1.4bar) with my powerFC.
given the size of the injectors and running these medium sized turbos, do i still need to worry about running this fuel pump at a constant 12v to get the fuel for 450-500 crank hp?? or will standard wiring hold up?
i imagine mpg with 700s isnt great, if i can help it, id rather not run them 12v all the time, lol.
if i do need to go constand 12v route, ive done a "search" and i cant for the life of me find out which wires i would need to splice/cut into specially for this fuel pump modification??
i have decent wires/4pin relay and fuse to hand, so believe i have the bits needed to make it work, but does this new wire need to connect direct to the pump (in the tank) or can i use a spade to plug into the + and - terminals on the fuel tank cap?
which wire do i need to splice into for the relay to trigger the pump to prime and work?
cheers
cheers
