I was doing some spirited driving last weekend. I was about an hour away from home and I noticed coolant temps we're rising. Pulled off to the side, let it cool down and checked the coolant. Radiator was bone dry. Filled up back up and limped the hour drive back home. Upon getting back into the driveway, I noticed temps climbing again. The next morning I checked the coolant again, bone dry. Also when driving back the car sounded strange, Almost like a Subaru. It wasn't quite misfiring, it just sounded off. Naturally I did some digging.
The car isn't leaking coolant anywhere, so it has to be burning it. Which leads me to guess the head gaskets done. Tried some of the usual tests and came back with some off results.
-No coolant in the oil
-No abnormal smoke out the exhaust
-No sweet smelly smells.
So I figured, hell, compression test.
1- 160 psi
2- 172
3- 160
4- 158
5- 148
6- 149
Now i'm a bit stumped. Compression across the board doesn't look TOO off. The random 172 was kind of eh? but other than that for a 20 year old car I don't think the HG should be giving it the problems it's having. Then I read a post on an old thread from a "Seasoned" member saying something about how it's somewhat common when the head overheats and warps, the back side near the 5th and 6th cyl warp first, crushing the HG.
So my question is, Do you think the lower compression on the last two cyl are enough evidence to pull the head, Or could my problem be somewhere else?
I've got most of the parts ready to start my top end rebuild and turbo swap, but not quite all of them. I'd rather wait a couple weeks to obtain the rest of the parts, than replace the HG now. Two birds one stone right?
Sorry for the essay! Any suggestions/criticism welcome.
1- 160 psi
2- 172
3- 160
4- 158
5- 148
6- 149
