Hey everyone I'm in the middle of buying parts for my 600whp build and could use a little or a lot of help/ suggestions on what all should be done : replaced on my Gtr .
I put together a list and it includes
Cp pistons 86.5mm
Eagal rods
Arp head studs
Acl main bearings 0.25
Acl rod bearings 0.25
Tomie 1.5 mm head gasket
Oem gasket set
Tomie 264 lift cams
N1 water pump
N1 oil pump
Tomie manifolds
Devided dumps
Hks hi power exhaust ( already have )
Rc 880 cc injectors ( already have )
Power FC d jetro ( already have )
Water meth injection ( already have )
Tomie timing belt and pulleys ( already have )
R33 crank if needed might use r32 with jun collar if it check out okay form shop
R
Also have nismo turbos I believe there kinda like the n1s
But I don't think ill get 600whp with them
Any info or suggestion will be greatly appreciated since this is my first major build
Cp pistons 86.5mm
Eagal rods
Arp head studs
Oem gasket set
Tomie 264 lift cams
N1 water pump
N1 oil pump
Tomie manifolds
Devided dumps
R
