Hey guys, my car is running terrible. Hard to rev passed 3k, black smoke sometimes. Intermittent power, choking, bucking, sputtering. All the verbs you can think of. When i turn my key to the on position and the rail pressurizes i can see fuel seeping out around the injectors. I've ordered a set of seals, I'm just curious if the black smoke could be caused by the bad injector seals. I guess I can only speculate until I install new ones.
Black smoke/injector seals
black smoke means excess fuel, rich, not fuel leak. The fuel leak was there before. take your maf out and brake clean it. if you cant drive it at all, check intake pipes, maybe blew an interccoler pipe off.
you need new injectors btwBlack 1991 GTR. Serious garage stand mantle/parts car.
Nah, wouldn't be ballast causing leaks because it works or doesnt (fuel or no fuel). Might be a bit more leaky on prime since its just building up not being injected. You need new injectors. Buy new ones and retune or used stockers.Black 1991 GTR. Serious garage stand mantle/parts car.
