ok thats cool gtr
  • ok thats cool gtr
    Hi, guys. I just swapped out my coil loom yesterday for a wiring specialties harness. I went for a quick run up and down the road and all was well. I went out this morning to swap out my mines ecu for a stock one I have. Started the car and cyliner 1 has no spark. I swapped the coils around and still cyl 1 has no spark with any coil. I visually inspected the ecu connector and immediate wires and they look fine. I get 12v to the coil when key is in on. I've since swapped back to the mines ecu and the problem persists. Really wish I would have started it before I swapped the ecu. Im thinking the ignitor is ******, anyone care to chime in?
    Yeah. Back pedal more. (check harness connections INCLUDING the ground wire to the ignitor). Use the stock harness and see if that fixes the issue.
    No build thread.
    1991 nissan
    El terror
      I had something like this happen to me last year. Check pins on coil aren't bent. Also wires on the ecu plug from harness. I had one that was just a little loose.
        Ecu connector!, it was flexing when being tightened, thanks for the help guys
