Ebay z32 n62 MAF's thoughts?
  • Ebay z32 n62 MAF's thoughts?
    Found these on eBay. What's everyone's thoughts on these? They should work fine correct?
    Those are the non turbo ones not sure if thats going to make a difference, also they may not read as accurately, or take as much airflow as genuine z32 mafs. I don't know much about mafs though so hopefully someone with more knowledge shows up eventually, but i think its a poor idea
      Why buy ebay ones when you can get good working used z33 mafs for like $60-80 each
        they are N62's tried it and worked but only during my break in period running 10psi so not sure how long or how well it does at higher loads, then i found a cheap set of genuine used mafs
        also, forgot to add, the 4 bolt mounting surface was not perfectly flat, it was kinda curved so that was kinda annoying too
