Tire rub on front upper control arm/drivers side
  • Tire rub on front upper control arm/drivers side
    On my way back from a cruise last night the front upper control arm on the drivers side began rubbing the tire on every small bump. I have gone over everything and can't seem to find what's causing this? I checked the coilover first then pulled it out and gave it a complete inspection, everything is fine and the adjustments match the other side. Ball joints are good and nothing seems bent or loose. The control arms were replaced last winter with adjustable cusco ones. I have been driving the car since mid June and competed in one auto x event with no problems. I took a few hard corners on my cruise last night but the rubbing started on the way back when I was taking it easy. The arm is sitting about 1/4 inch above the tire while the opposite side has about 1 inch, which is normal. I'm posting to get some help on solving this problem, if you have any ideas or suggestions it would be a great help!
