So when i bought my car it came with a spare head. Previous owner said he had a low cylinder, so he got a new engine, junked the block, and kept the "still good" head. This being said i started taking it apart now, as im gonna build a head with my new poncams, some manley springs/retainers, and maybe a +1mm exhaust valve bore with new valve seals.
So when I started taking ti apart, I noticed the exhaust cam had a chip or two out of it, and when removed it revealed more chip damage on one lobe.
So then i noticed the head. Theirs a gouge out of the head...
It doesnt seem to have any valve wear or anything out of the ordinary with the valve guide or anything... But for the life of me I cant figure out how this would happen. It would be a pretty serious jump for the lobe to hit the head that far away while still bolted down. The cam caps were all good, none loose. I did also notice a slight wear above the norm on that bearing too.
I guess my question is if this head is worth rebuilding. Im considering taking this to the local machine shop to see if it can be ground out of the head and plained flat. It looks to me like it wouldnt make much difference if repaired (cams are junk), but Im not sure what would cause this, so im timid about the valve guides and if its gonna have issues.
Just looking for input.... Please keep in mind I live in the armpit of canada and no one here has spare heads/blocks. I am still looking for a spare block without much luck cuz no one wants to ship one
