Sup All,
I just bought a Megan Racing Decat Pipe (with bung for temp sensor) for my '94 R32 GTR but before installing it I started doing some research:
I see alot of people saying to just cut the temp sensor and the engine light will not come on. Some people say once cutting the sensor though, the light comes on. I need some feedback on this for this reason: my temp sensor is a bi**h to remove lol. 14mm is too big. 13mm is too small. 9/16" is too big. 1/2" is too small. Adjustable wrench will not grip...wtf right?
Next: say I do get the sensor removed from the stock cat, will putting it into the bung of the decat get high readings leading to an engine light anyway seeing as the internals of the cat will no longer be present, and temperatures will ultimately be higher? If this is the case, should I just tie strap the sensor to the underside of the car with some protective covering over the end? I would like to avoid cutting it for the reason that I live in the Cayman Islands where there are absolutely no emission tests but if I wanted to move to Canada (or anywhere else) and bring my GTR, I would need to keep the stock cat and sensor for passing emission standards there.
Lastly: The 14mm bolts that attach my cat to the cat-back system are not budging. Any tips/suggestions to get these off without cutting the flange? I tried using WD40 to loosen them but nothing. Maybe LiquidWrench? CorrosionX? Like I said, I want to be able to put the cat back on if I were to move to a place where emission testing is present. The Megan Racing Decat does come with new bolts and nuts and gaskets, so if push comes to shove, i could cut the old bolts, but honestly, I'm not versed in welding/cutting torches (or dremels for that matter) so any feedback here would be much appreciated as well.
TL/DR: I want to be able to replace my cat with a decat with the option of replacing the cat in the future. Odd sized nut. Seized nuts. Any engine light issues?
