Hi guys,
Here is our (our as in me and my spouse, we are co-owners) project car. This is a special edition GT-R tuned by Veilside at their garage. Most of the work you see was done by them. After the car landed, we fixed a few things and we made sure that everything was A-1 before we do any serious driving. After almost 1 year of babysitting this GT-R and making sure everything is solid, we took it to a dyno. The result is 502whp @ 8000 rpm on 16psi of boost. All this on pump gas of course.
Modifications
Engine
2x Top mounted IHI RX5 turbos
2x External HKS S/S Racing wastegates
HKS Race Cams (IN66° lift 9.5 EX68° lift 9.5)
HKS adjustable Cam gears
N1 pistons
N1 pumps
Bosch 660cc injectors
Splitfire Coils pack
Metal head gasket
NISMO fuel pressure regulator
HKS oil filter relocation kit
HKS GT intercooler
HKS blow off valve
Twin-plate OS Giken clutch
Fujitsubo Super Legalis R Stainless Steel exhaust
Polished intake manifold
Cusco aluminum catch-can
Electronics
GReddy boost meter
HKS turbo timer
HKS electronic boost controller
HKS VPC
Omori gauges (exhaust temp - water temperature - oil temperature - oil pressure)
Innovate Wideband O2 Sensor
NISMO 260km/h cluster
Almasi Tuned ECU [Replacing HKS PFC F-CON]
Handling
Gab suspension
Cusco strut tower brace
Sway bars
Full Roll Cage
Desmond Regamaster wheels
Dyno sheets
Note: Numbers done on a Dynapack in rear wheel drive mode on a hot, humid day
Flywheel HP vs Flywheel TQ (computed using a 1.18 ratio)
Wheel HP vs Boost (PSI)
AFR vs Wheel HP (AFR is off. 12.5 is actually 11.8, so the entire scale needs to be lowered by 0.7)
Pictures (Not so great, will work on that!)
Front
Side, displaying Veilside original graphics
Engine Bay
Top mounted turbos
Modifications
Engine
N1 pistons
N1 pumps
Metal head gasket
HKS GT intercooler
HKS blow off valve
Electronics
GReddy boost meter
HKS turbo timer
HKS VPC
Handling
Gab suspension
Sway bars
Full Roll Cage
Dyno sheets
Front
Engine Bay
Top mounted turbos
