Hold on, you went with an N1 bottom end (one of the more expensive blocks) and an N1 oil pump (one of the cheapest oilpumps)? Anyways, nice numbers, is that on race gas? What kinda of AFRs did you tune with? How's the shuffling and response on those?
O5U Block, 24U Pistons & Rods & Crank. Running on Sunoco 94, with 50/50 water meth mix, running 23lbs of boost. ran 11 afr's up in the high rpm range. no shuffle, stable cruising on the way there and back. Idles at 1200RPM.
