@mitch32 - tell me more about which clutch + flywheel combination you got? and where from and how much it cost... i want something thats like a full kit, i like the exedy stuff but its rather costly.
well 2 nights ago had some buddies over so we put the body panels back on....
heres the hood, its actually super light but i just wanted to be super careful and get it line up perfectly
there now that looks good!! except for all the dust.
so im waiting to install the fender liners and under trays because tomorrow im gonna try and fix the oil leak...speaking of which i was able to snap a photo of what exactly is leaking. like i said, its by no means a large leak at all. but still.. i want 100% confidence in my car, no leak is acceptable!
so like i said before its the banjo bolt that connects the 2 oil feed lines to the engine block.... *sigh*
anyways, i had only 2 hours today between waking up and starting work, so i started on my center console.. i began by measuring the CF board i had to fit perfectly behind the center console trim piece.... want this to look clean!
then i mapped the cutting plan.... (the edges of the CF arent 100% straight so i had to make some minor corrections so that the things would sit straight even if the edges were not....looks kinda... smiley!
so the Defi gauges are water temp and oil temp, and thats the Link II system controller... i didnt want anything with super flashy bright lights in my field of vision (defi's are brightness adjustable woohoo!)... thats why every thing on and around my dash is Red Led's... red is the color of the spectrum that is least bothersome to drivers... gotta keep the focus on the road!
so the 4 round things are rivets... the rivets hold a bracket... and the bracket holds the defi controller in place.... pretty clean i think.
so later tonight ill wire it up, and mount it as it should be...
below the controller is where the future "stereo" will go... so ill cut that out when the time comes as it might be a while before i buy any stereo...lol
the turbo timer, boost controller (to be purchased) and traction controller (to be purchased) will go in a different location.... you'll have to wait and see!
