backfire maybe?
Originally posted by Ricky Ricer View PostIf you go this route I can help you Frank.
im going to buy just 1 new injector, and have them all cleaned up like new
and buy a new pump too
the principal problem is the IC pipe blowing off
but the injector has been leaking for a bit, and is now a goner
and since im still not sure what pump is in my fuel tank, and that its making weird noises, im going to swap it
then get a retune, again
Incorrect, unless they morphed into GTR injectors for the photo. Nismo 555's are purple like Tomei's. Stock GTR's are a yellow cap like pictured.
nismo 555cc injectors, unknown a/m fuel pump
lol mark, i think playing around with fluo apparel as messed up your color sense bro'
the nismo 555 are beige, the stock 444 are really really yellow
i have 555s, i have spend over 10hours total on the dyno with this car, they are 555s
this is yellow:
I see.. Even though Nismo top feed 555cc injectors are pink... side fed are yellow.. OEM are yellow, or seemingly beige if they've never been cleaned.. But don't take my word for it!
RHDJapan offers the best quality performance parts made in Japan including Nismo, Mugen, Defi, Spoon, Cusco, Tomei, HKS and other JDM brands.
I think my eyes are fine.. But i guess we'll find out for sure when you get the rest flow tested
just saaayyyinggg..Check out the GTST Projects page and keep up to date with my build!
sit-rep
i reconnected the IC pipe, which was totally BS, still can't understand how it popped off, it took 3 hours to take it out fixe stuff, and put it back in correctly
fired the car up, and it was obviuous i was running on 5 cylinders
so i did a compression test, and got a ~160 average all around, so motor is not damaged at all
sent my injectors to get rebuilt/cleaned tested, and as i tought, no3 injector is FUBAR, so i got to replace it asap
oh and the injectors would be Bosch VLT 550cc injectors apparently
so i might order 1 nismo 555cc injector
will post pics when i canLast edited by frankiman; 08-23-2011, 03:45 PM.
