Since old owner lie about engine setup i sold the engine (stock r32 )bare block n head wit intake n i keep all the rest of the motor !
Here is the true PART list for my car for 2012
Moteur:Swap r34 2000 20 000km
HKS T4 DIVIDED MANIFOLD (CAME FROM A T51R KIT)
HKS 60 MM WASTE GATE (1 BAR SPRING)
S362 TURBO (SPECS NOT TELLING THEM BEFORE DYNO)
CUSTOM 3 INCH DOWN PIPE VBAND FROM THE TURBO
CUstom bit of a piping after the turbo
CUSTOM OIL LINE
Apexi complete cat back*
Greedy type r BOV
Tomei head gasket 1.2 mm 87 bore
Tomei timing belt
Tomei oil pan baffle
Tomei TYPE b camshaft
Tomei cam gears
Spool oil drain kit
Yellow jacket coil pack
Hks intake wit custom pipe*
Nismo engine mount
Cusco OIL catch can 3 liter wit stainless steel braided line
Drivetrain:
Cusco type RS 1 WAY FRONT LSD
Cusco type RS 1.5 WAY REAR LSD
R34 6speed getrag (20 000 km)
1 piece allu driveshaft (driveshaftshop)
Nismo twin plate competition model
Nismo r34 tranny mount
Nismo r34 stainlesssteel clutch line
Fuel system:
1000 cc denso injectors
Greddy twin entry fuel rail
Sard fuel pressure regulator
Sard fuel pump wit relay 280 lph+
Cooling system:
hks piping kit*
Arc 4 inch intercooler
Mishimito radiator
Nismo low temperature thermostat
Trust greedy oil cooler wit filter relocaliser
Ecu:*
Apexi Power fc d jetro (map sensor)
Tuning almasi*
Apexi boost control kit
Gizmo Electronic Lunch control , tach recall, shift light
Braking stuff
R34 brembo wit project mu brake pad
Stainless steel braided line
Suspension :
cusco type zero 1 coil over kit
Ams hicas delete kit
Ams front upper table
Ams tension rod
Ams rear Camber ajuster
Ams Inner + outer tie rod
4x new front balljoin
Roller:*
17x9 +15 offset work rsz-r*
275-40-17 g force kw2 tire*
Interior:
cusco 7 pooint rool cage*
Nismo gt500 6mt shiftnknob 12mm
Recaro sr4 blue*
Bride low position seat rails
Alpine radio*
Z sport cluster 320kmh
Razo foot pedal
Defi oil pressure gauge
Defi boost gauge
Innovative wide band
Sard battery relocator kit /sard box
Exterior
N1 Headlight
Nismo front bumber
Nismo side skirt
Nismo rear valence
Fluids:*
Tranny;Motul 300 gear oil api-gl4 75w90
Nissan matic d transfer case
Front diff+ rear diff
Motul 300 gear oil 75w90
Engine:
Motul 15w50
Oem oil filter
CUSTOM OIL LINE
Greedy type r BOV
Tomei timing belt
Tomei cam gears
Spool oil drain kit
Nismo engine mount
Drivetrain:
Fuel system:
Cooling system:
hks piping kit*
Mishimito radiator
Ecu:*
Tuning almasi*
Braking stuff
Suspension :
Ams tension rod
Roller:*
Interior:
Recaro sr4 blue*
Alpine radio*
Razo foot pedal
Defi boost gauge
Exterior
N1 Headlight
Nismo front bumber
Nismo side skirt
Nismo rear valence
Fluids:*
Engine:
Motul 15w50
Oem oil filter
2000$
