Hey Guys,
Just thought I would throw a post of my car etc, what Has been done to the Motor, what i've done to the car, etc..
Soo Motor.
Ross Pistons
Manley Turbo Rods
ACL Main Bearings
ARP Head Studs
Custom Made Main Studs
JUN Crank Collar
Nismo Oil Pump
Nismo Water pump
OEM Gaskets
Tomei Head Gasket
Tomei ProCams
Tomei Springs & Retainer
OEM Valves
Untouched Head(0 porting or polishing)
XS Power Turbo Manifold
Borg Warner Bullseye S366
XS Power InterCooler
3.5" Turbo Back
RC 1200cc Injectors
HKS Fuel Rail
AEM EMS 2 Stand Alone
Mishimoto Aluminum Rad W/ Electric Fans
44mm WG
So Basically This is the List into my Block and Bolt ons. Some specs are un mentioned. because well their always needs to be some secrets in a build =D
Anyways I just happened to stumble into Magnus as they were tuning my car and I hear that the car made 520Whp.
Of corse i was happier then a pig in ****, If you guys know the company you know how Marco is.
He walks into the office " WTF Did we put a F@CKIN Stroker in this. WTF," He walks back out goes to clean the tune up does another pull and comes back in to the office " WTF it just made 550Whp. it just keeps building power."
To add to this pointless story, The boost controller isnt hooked up so its opening at WG pressure which is just under 20lbs and on average the car is running rich as its the break in tune on the motor. The motor only Has 1200 KM on this date. The car was also Detuned back to 520 to ensure nothing would happen to the block during the break in.
This was pretty much a stock rebuild with stregnth. It just shows what Quality gives you.
Soo Motor.
Ross Pistons
Manley Turbo Rods
ACL Main Bearings
ARP Head Studs
JUN Crank Collar
Nismo Oil Pump
Nismo Water pump
OEM Gaskets
Tomei Head Gasket
Tomei ProCams
OEM Valves
3.5" Turbo Back
RC 1200cc Injectors
HKS Fuel Rail
44mm WG
