1991 r32 gtr
  • 1991 r32 gtr
    So ive finished my engine build. Im not sure how much i should push my car to find a safe power number. My tuner says its completely up to me. However its kind of concerning to hear " we can just push it with boost till it doesnt accept it no more". Here are my mods on my car. can someone with experince or with similar mods give me some advice and where to stop.
    Rb26 Rebuilt
    CP Pistons
    Mauler Rods
    ACL Race bearings
    R33 Crank
    N1 Water Pump
    N1 Oil Pump
    Port and polished head
    270 cams
    Tomei Head Gasket
    Tomei Head Studs
    HKS Cam Gears
    Greddy Intake Manifold
    Yellow Jacket Coil packs
    GT2860-5 Twin Turbos
    880cc Injectors
    Bosch 400lph Fuel Pump
    Link G4 ECU with boost controller
    its getting tuned this friday im not sure what to expect. please help, thanks!
    With the smallish fuel set up you've got I wouldnt go more than 500 at the wheels (the biggest limiter is your pump).
    The engine though should be able to hold 800 without much stress. As long as the brging clearances were kept on the loose side you should be in for a hell of a ride. The biggest killer of RBs is the oil clearances, most builders make them too tight. And FYI the stock clearances are too tight for a high winding, high power engine. I hope your builder knew that. If he did stock clearances, dont go over 500 engine hp for at least 10,000km.
