Hi All,
My name is Wilson and I have been with this forum a long time ago with a 1991 Skyline GTS-T which was sold to another user on this forum named A18. I hope he enjoyed it as much as I did.
Anyways, fast forward to today, I have been through several cars:
1988 Mazda RX 7 FC3S
2000 Honda Integra Type R
2011 Subaru WRX STI
I recently sold my STI for the purpose of reducing some debt and after searching the market for a car, I started looking at Skylines again. It's always been my highschool dream to build one and I wasn't satisfied owning the GTS-T.
I purchased late June 2012 this 1990 Skyline GT-R from a mechanic in Richmond that claims to be a "skyline specialist". Of course like any purchase of an old car, you should do your due diligence and get the car inspected. I kind of overlooked this process as I trusted his status as a mechanic and expected quality work done on the car. Unfortunately this was not the case as I will describe the bad below. I must say though, BUYER AND SERVICE BEWARE of Koju Takeda of Takeda Enterprises.
Instead of ranting, there's nothing much I can do now, just never bring the car back to him.
Here is my build thread, starting off likely with maintenance:
This picture shows the paint better than it appears, it will need a full detail.
Came with:
"Rebuilt" (claimed) engine with less than 5,000kms
First oil change (Motul 8100) included with the purchase, but used a crappy $2 oil filter
Air filters
Nismo Air Filter Arms
New HKS turbos, which after inspection was stock housing with claimed HKS internals (not sure yet)
Apex-i full catback exhaust including testpipe
HKS Camshaft
Compustar 2-way alarm
Tecnomagnesio 5-spoke 17x9" alloy rims
Nismo Copper mix clutch and flywheel
The bad:
Leaking Rear Hicas Pump (from engine bay)
Leaking coolant lines from the turbos
Leaking oil dip stick holder (it appears to be bent and hammered, will need full replacement)
Possible leaking of rear differential
Slow leak on the transmission casing (middle of the car)
Fuel line to the fuel rail was leaking fuel due to oversize hose installed
Unfortunately it did not appear like this when I reviewed the car prior to the purchase. I took it back to him to fix a couple times without resolution. After the "fixes", I noticed several clamps that weren't put back on securely, nothing in the engine bay appeared to be wiped down or brake cleaned after the service and thus I was not impressed.
Moving forward, my personal mechanic who has shop in Richmond, Evogarage, will be handling my car and has made several fixes to the car to ensure it still runs.
Currently on order:
- Used HKS Hypermax 3 Coilovers (from GTRC member Derek240)
- Driftworks Hicas Full Eliminator package
- Driftworks Steering Rack full metal bushings
- Driftworks Front and rear differential solid metal bushings
I will also post several pictures of the repair, if I have time to visit my mechanic when he performs it.
Thanks for reading and sorry for the long post!
2011 Subaru WRX STI
Came with:
Air filters
HKS Camshaft
The bad:
Currently on order:
