I bought my skyline on monday off a friend who decided, on monday, to sell it. It was an opportunity I couldn't pass on, my first plan was to purchase an s13 and throw in an ls3 as a drift car. Plans change and I think it may be for the best!!!
These are parts that are on the car and also not installed yet.
SUSPENSION:
- DRIFTWORKS Multi-Link kit ALL ADJUSTABLE WITH BEARINGS includes Front adjustable tension rods, Front upper camber arms (GTR/Q45), R33 style rear upper control arms, Rear traction arms, Rear lower control arms HICAS eliminator kit
- Buddy Club N+ Spec racing coilover system with Pineapple bushings and Spherical bearing camber plates. 38 way damper adjustable
- GTR Rear subframe, sandblasted and powder coated black. Solid aluminum bushings with adjustable height collar (for raising or lowering the subframe),
- GTR front subframe, sandblasted and powder coated black, includes front lower control arms with new inside ball joints
- GTR differential, LSD with 1000HP axles and the driveshaft yoke.
- GTS rack and pinion with urethane bushings, URAS forged inner tie rods (with machined 3mm spacer) Ikeya formula rod end outter tie rods with GTR and GTS pins
- GTR hand polished spindles (front and rear) bearings, with 55mm extended wheel studs. Front King pin arm sandblasted and powder coated black
- GTS gas tank
- R32 headlights, N1 style, OEM
- RB26 N1, 24U block code (highest Nickle content block), freshened up 3 years ago. Long block
- R32 GTS 4 piston front, 2 piston rear calipers. Rebuilt with new seals and boots, powder coated GOLD with RED Nissan
- Powerslot 14" Rotors for G37, Zinc coated, cross drilled and slotted
- Apexi N1 exhaust system
- 2x XXR 502, white, 18x9.5" +35 offset, Federal 595 225/35ZR18 mounted and stretched
- 2x Fast Wheel Enkei RPF01 replicas, without tires
- 2x Fast wheel 19x8 with General Tires
-Apexi DECS 5" tachometer, Oil pressure and temperature LCD display White backround to 11k
- PLX Devices IMFD datalogger, Live Tune.
Chassis
-1992 r32 sedan, stripped interior undercarriage gravel guarded, engine bay and interior painted astro blue. Molded gtr tail lights
What I am getting
-twin gt28-60
-tomei manifolds
-greddy intake manifold
-750cc injectors
-2x38mm wastegates
-greddy profec spec b2 boost controller
-greddy ls intercooler
-mishimoto rad/fans
-rb25 tranny
-aluminum driveshaft
-hks hyper single clutch
-2jz fuel pump
-aem ems
-painless wiring harness
-N1 revised oil pump
-greddy tru time timing belt
Thats just a quick list more to come. Advice, criticism and feedback all welcome first time building a skyline.
SUSPENSION:
- GTS gas tank
Chassis
What I am getting
-twin gt28-60
-tomei manifolds
-750cc injectors
-2x38mm wastegates
-mishimoto rad/fans
-rb25 tranny
-2jz fuel pump
-aem ems
, keeping stock cams. Run my brake lines, cut trunk and fab up a bracket to hold the fuel cell while using the oem filler neck. Run the ss line for hydro ebrake. Stil lots of planning and thinking ahead!!!
