So I have/doing some small stuff to my car before I put it away for the winter. So its not much of a build as of now, but ill add to it as time goes on.
To do/install:
-Paint all valve covers, replace gaskets
-Paint Apexi Intake system, clean filters
-Replace Nismo s-tune suspension with HDS Mono Coilovers
-Change front/rear diff fluid
-Fix leak from transfer case
-R34 GTR seats, 18x10 rpf1 wheels
-Nismo slave cylinder
-Interior details (gaugues,trim, etc)
-Change other fluid/oils, gaskets and what not.
Im sure there is more, but i will update it as time goes on!
pulled car into garage, started to take off some parts and put it on jack stands
Engine bay before
On 6-ton stands, was nice to have it up so high, easy to work on!
found some HKS Cams!
Divided Twin Turbo Pipe
Got my HSD Mono Coilovers in! (came with lafy tafy for some reason.. maybe a uk thing?)
Before/After Nismo S-tune suspension and HSD, the s-tunes were nice, but wanted to go lower!
Coilovers are in, very easy to do! (wheel wells are a little dirty..)
Wheels came in!!
Valve Cover after paint (dont mind the duct tape on my vw mirror..)
Painted Twin Turbo Pipe Gunmetal Grey as well!
Transfer case had a lil leak, hopefully i fixed it!
18x10 +20 RPF1 w/265/35/18
Changed all valve cover gaskets, and cam seals. Put valve covers back on
More to come!
To do/install:
Engine bay before
Wheels came in!!
More to come!
