Well after some upsetting compression test results last September after I bought it, I decided to tear into my '89 R32 GTR.
This would be my first build with these type of cars as I used to be more into domestics and such, but anyways.
After battling misfires, and rough running I ran a comp test last season with results of 160 160 159 160 80 60
Parked the car and began tear down. There was some questionable work done to this car so I pulled the engine and trans and tore down completely. Dont have a lot of pictures of the tear down and not many of the build back up. As it happened over the winter and when I got new parts I was excited to install and not take pics.
Long story short, when I pulled the head apart I had smashed valve keepers on cylinders 5 and 6 on intake side. Valve lash was too tight causing major valve float on the dyno. And my exhaust cam was 5* out. Got that all straightened out, learned a lot about degreeing and assembly on the RB26. Had stock 25 yr old valve springs plus a valve grind, with Type B cams, probably not so good my guess is it was over-revved. Replaced with Tomei Type A springs (recommended for my lift) and ferrea titanium intake valves. Exhausts were new when I pulled apart.
Did and ABS removal while I was in there, and a few other things to neatened the bay area. Overall I am fairly happy with the way things turned out. Still some street/idle tuning to do, then onto the dyno for WOT tuning.
Info/Parts list:
•Garrett 2860-5 turbos
•HKS Dumps
•4” koyo Intercooler
•Race bearings
•ACL eagle rods
•ARP head studs
•CP forged pistons 87 mm
•CP clips
•CP rings
•Cosworth head gasket
•Protex water pump
•N1 oil pump
•Tomei type B cams
•M’s intake
•780 cc injectors
•AEM E85 fuel pump
•Apexi power FC ECU
•HKS EVC
•4” HKS hi-power exhaust
•OS Giken Twin plate clutch
•AHR Adjustable cam gears
•HKS piping
•Spit fire star flag SE-DIS-001 Coil packs
•SR Jasma down pipe
•Decked
•Honned
•Pistons/clips fitted
•Ferrea Titanium Valves
•Tomei type A springs
•Polished crank
•Magnaflux block and crank
•Port and polished
•Carbon fiber Seibon hood
•Carbon fiber Nismo lip
•Carbon fiber Nismo trunk lip
•Nismo 320km cluster
•Brembro front breaks
•N1 head lights
•Blidz 17” rims
•Front and rear strut bars
•Tein control master type flex coilovers with electronic dampening control
•Schorth 4 point harness
•N1 shift boot/ ebrake boot
•Apexi side skirts
•All black interior
Sure I am missing lots but that's mostly the major things.
[IMG]
[/IMG]
Assembly
Complete car pictures keep in mind I don't have my wide summers on, and suspension hasn't been set up yet.
Info/Parts list:
•HKS Dumps
•Race bearings
•ACL eagle rods
•ARP head studs
•CP clips
•CP rings
•Protex water pump
•N1 oil pump
•Tomei type B cams
•M’s intake
•780 cc injectors
•AEM E85 fuel pump
•Apexi power FC ECU
•HKS EVC
•HKS piping
•SR Jasma down pipe
•Decked
•Honned
•Polished crank
•Port and polished
•N1 head lights
•Blidz 17” rims
•Apexi side skirts
•All black interior
[IMG]
[/IMG]
Assembly
